Monte Carlo update
jamundsen
Re: Monte Carlo update
Postby jamundsen » Fri Jun 11, 2010 11:10 am
I'm the sweaty one in the yellow shirt. Actually it wasn't bad at all. We hooked my truck to the strap and just slowly backed up and then the boat was right side up.
John Amundsen
Monte Carlo
Lakeland,Fl
Postby vupilot » Fri Jun 11, 2010 11:28 am
You actually got Alcorn to do some work? :lol:
Looks great John. That is a BIG boat!
ttownshaw
Postby ttownshaw » Fri Jun 11, 2010 11:59 am
Yippeeeee! Man that looks great!!!!
http://www.unitybuild.net
jamundsen
Postby jamundsen » Sun Jun 13, 2010 6:03 pm
Boat grew since it was turned over. Its a lot bigger than I thought. So now I'm sanding the interior to clean it up before epoxy coating. Also working on the sheers lines. does anyone with a barrel back have any pictures of the rear section by the transom before putting on the deck?
John Amundsen
Monte Carlo
Lakeland,Fl
Postby vupilot » Sun Jun 13, 2010 6:29 pm
I think boats grow twice during the build John. Once when you flip em and again when the deck goes on. Oh, and its always bigger when youre sanding.
DaveLott
Postby DaveLott » Sun Jun 13, 2010 6:35 pm
jamundsen wrote:Boat grew since it was turned over. Its a lot bigger than I thought. So now I'm sanding the interior to clean it up before epoxy coating. Also working on the sheers lines. does anyone with a barrel back have any pictures of the rear section by the transom before putting on the deck?
It grew. NO KIDDING. I was waiting for you to say that.
Glen-L Sea Kayak
Mahalo Standup Paddleboard
Video of Midnight in Action
gluedandscrewed
Postby gluedandscrewed » Sat Jun 19, 2010 11:28 am
I can read your mind John, I agonized over that joint for weeks. What i did is too late for you however, I flipped her over before fairing the sheer and putting on the aft side planking. Screwed on a temporary template of the deck line that was fair and brought the sides up to it. Going from a flush deck to side joint at the trasom to vertical deck edge amidship only required a tiny fillet run with a teaspoon to look half assed ok. Could not figure out any other way to do it.
gluedandscrewed
Postby gluedandscrewed » Sat Jun 19, 2010 12:17 pm
Sorry for the blond moment John,,,, forgot yours is mahogany sided, I'm painting my sides. But the problem is the same.
jamundsen
Postby jamundsen » Tue Jun 29, 2010 7:46 pm
So many projects..so little time. How many degrees of turn should the rudder have? Is 45 degrees each way enough?
John Amundsen
Monte Carlo
Lakeland,Fl
DaveLott
Postby DaveLott » Tue Jun 29, 2010 8:10 pm
John - My rudder turns 45 degrees at most and performs just fine.
Glen-L Sea Kayak
jamundsen
Postby jamundsen » Wed Jun 30, 2010 9:32 am
Good I was hoping that 45 degrees would work. Next question is what type of fastener should be used for the shaft log? Mine is for 1 1/4 shaft and is fairly large. I have found silicon bronze lag bolts but they are about $10 each for a two inch long X 1/4 diameter. There are ,I think, 12 indents for the fasteners on the shaft log. Would I have disimilar metal issues if I used a different fastener like stainless? This is inside the boat not in the water. Would #10 wood screws be satisfactory?
John Amundsen
Monte Carlo
Lakeland,Fl
DaveLott
Postby DaveLott » Wed Jun 30, 2010 10:13 am
John - I suppose you are talking about the strut not the log.
I would bolt but I did not pay anywhere near that amount per bolt in silicon bronze.
Let me look at my source and pricing and I will PM you
dave
Glen-L Sea Kayak
Postby Bill Edmundson » Wed Jun 30, 2010 11:11 am
John
Galvanically, stainless, bronze and aluminum are very close. So the dissemilar metal is not an big issue.
jamundsen
Postby jamundsen » Wed Jun 30, 2010 11:20 am
It's truly amazing all the things one can learn on this forum.
Dave it's the shaft log. The strut and backup are finished only awaiting the bronze machine screws, which weren't bad in price. The shaft log is pretty hefty as it's for 1 1/4. Pictures are on the way.
John Amundsen
Monte Carlo
Lakeland,Fl
DaveLott
Postby DaveLott » Wed Jun 30, 2010 12:01 pm
John - Slap some polysulfide on that flange and screw it down with #10s. I have #8s on mine but mine is 1". There is little to any pressure applied to the log. It is just a water dam. The seal takes the abuse from the shaft. I cannot fathom a need for bolts on the log.
dave
Glen-L Sea Kayak
