CRACKER BOX
TUGMYWAY
Re: CRACKER BOX
Post by TUGMYWAY »
Love the dock photo's! So very cool. :shock: The Box is looking very good also! :P We need to see her in the water,now get back to work! :twisted:
Randy :mrgreen:
fergal butler
Re: CRACKER BOX
Post by fergal butler »
For the seats I used 1/4 ply and a layer 1/4 mahogany the back has 2" foam and the seat has 4"
I cut the foam a bit bigger than the board and then stapled it to the edge to give it a rounded shape.
The fabric was cut 3" bigger than the board and stapled on.
The seat foam was too thick to staple a curve in so I cut it away bit by bit till I got it close enough.
The sides and prop shaft still have to be covered also the back of the seat will be a little bit higher when fixed in place, not my best work but it saved me a few quid having a go at doing it myself :D
Re: CRACKER BOX
Post by neel thompson »
Seat looks great Fergal.. In the last picture, it appears that you have a switch panel hinged to the aft end of your motor stringers. What is that panel, and why is it hinged. You are doing a superb job all the way around.... When is the big day?
fergal butler
Re: CRACKER BOX
neel thompson wrote:Seat looks great Fergal.. In the last picture, it appears that you have a switch panel hinged to the aft end of your motor stringers. What is that panel, and why is it hinged. You are doing a superb job all the way around.... When is the big day?
Cheers :D The panel is not permeant I just have there for testing the engine the hinges were just handy brackets because of the angle. I might get her in the water before the end of the month to mark out the waterline and check for leaks, maybe a little run :D but she will be far from finished.
Re: CRACKER BOX
Lookin' Good, Fergal!!!
Roberta :D :D :D :D :D
fergal butler
Re: CRACKER BOX
What to do with a few bits of high density foam and a pack of girls tights :D
I shaped the foam and cut some slits 3/4 of the way through to allow it to bend then I poked a hole down through the first section and passed a bit of rope down it and tide a large knot.
Then poked a hole in the toe of the tight passed the rope through and pull the tight down over the foam cut off the excess and sewed it up.
3 new fenders that will confirm to the shape of the boat :D
fergal butler
Re: CRACKER BOX
Let's get ready to rumble. :D
Pullie
Re: CRACKER BOX
Post by Pullie »
Beautiful!!
SeaPea
Re: CRACKER BOX
Post by SeaPea »
looking fantastic Fergal!!
Craig
SUP
Riviera
red
Re: CRACKER BOX
Post by red »
looks great when is the bell going to ring for the first round
TUGMYWAY
Re: CRACKER BOX
Post by TUGMYWAY »
Very Well Done! :shock: Your hard work looks GREAT! :P
Time to go for a ride. :mrgreen:
Randy
fergal butler
Re: CRACKER BOX
The launch went well and the boat ran great up to 40 MPH then she started proposing so I may have to add a few wedges to act as trim tabs, she sat well in the water and level with my water line "shame it was the top of my waterline" :D I will try and get a video up later.
Joris
Re: CRACKER BOX
Post by Joris »
Looks like someone had a great day :D
I'll be dreaming about boats tonight, nice ones like yours!
Joris
Old aussie
Re: CRACKER BOX
Post by Old aussie »
top job fergal, boat looks great, love all the different photos shows the true lines of that beautiful boat.
Old Aussie Peter.....
