Monaco 19 - Pls assist
Report the performance of your boat, supply as much information as possible (weight, HP, prop, speed, etc.).
Subject: Make the Glen-L design name the subject. If the design already has a posting, add your information to that post.
siao tie
Post by siao tie »
Helo!!!
I am building the Monaco 19 and i would like your advice.
I have one engine 4,3 6v, 205Hp mercruiser model abt 1992.
Pls advice regarding ther dimentions of the propeler and also what kind of revolutions reducer i have to use, e.g. 2:1, 1:1 etc.
I was thinking to use gear reducer 2:1 but i do not know if i face any problem with the propeler dimension later on.
Pls assist, many thanks!
Trackhappy
Re: Monaco 19 - Pls assist
Post by Trackhappy »
Hi Siao,
Pretty sure 1:1 would be the right ratio. My Gentry is not dissimilar but 5.7LV8 and still 1:1 recommended. More than that and you would have to fit a much bigger prop, which would alter the shaft angle too much to get the clearance.
I am sure the "Pro's" will pipe up to upset the calm of the last few days... ;)
siao tie
Post by siao tie »
Many thanks!!!!
Return to “Speed and Performance”
