need helpfinding a prop!!
Report the performance of your boat, supply as much information as possible (weight, HP, prop, speed, etc.).
Subject: Make the Glen-L design name the subject. If the design already has a posting, add your information to that post.
tyst67
Post by tyst67 » Thu Oct 06, 2011 1:45 am
My boat is a homemade flatbottom 4 feet wide 14 1/2 feet long, and it weighs 182 pounds! My outboard is a 30hp mercury sea pro with a 10x17 blackmax mercury prop. My cavitation plate is 1 inch above the bottom of the boat. At full throttle my boats GPS's at 52 mph. But my motor is on the rev limiter. I have been looking at many different style props but im still confused about them all because all i ever used was the stock mercury blackmax prop. Here are some pictures of my craft and a video too please help me find what im looking for guys :D
tyst67
Re: need helpfinding a prop!!
Post by tyst67 » Thu Oct 06, 2011 10:35 am
Sorry couldnt put the videos on here is the vidoes on my facebook. http://www.facebook.com/profile.php?id= ... =788685404
wright6627
Post by wright6627 » Mon Nov 21, 2011 11:07 am
If you're on the rev limiter, you are underpropped. Based upon the nice top speed you're getting, i'd guess you might already have the prop you want. It can be modified. It can be repitched and then cupped. Talk to a good prop man and get his advice. He'll need to know the RPM you're getting and should be willing to work with you to repitch/cup your prop till your RPM is in the high end of the peak torque/HP curve. Repitching and cupping can add 3-4" of pitch to an unmodified prop--enough to bring your RPM down 500-600 RPM--and bring your speed up.
Good luck!
Randy
gstanfield
Post by gstanfield » Tue Nov 22, 2011 9:16 am
I'm guessing you'll end up going with a custom built or reworked prop. The highest pitch I can find for your outboard is a 10x17, which you already have. I'll do some digging, I have about a hundred or so websites saved just in regards to outboard parts maybe I get lucky :wink:
George
I Peter 2:17
Return to “Speed and Performance”
