Improving stability of the gentry
maninblack646
Post by maninblack646 »
Hi I built the gentry, finnishing it last fall I got it in for a few rides before winter. My problem was with handling and tracking. It wanted to slip from side to side at the tramsom at high speeds.
I'm thinking about adding racing fins to the hull or two short keels on either side of the main keel.
Can some one please give me some advice on what I should do? if I go with racing fins how many and were should I place them?
thanks,
jamie
Nova SS
Post by Nova SS »
could it be chine walking or is it doing a fish tailing kind of motion?
Scott
Post by Scott »
Is it rocking from side to side or slapping the water from bow to stern?
Thun.der.bolt
ˈTHəndərˌbōlt
Nova SS
Post by Nova SS »
Ok, Jamie sent me an email saying that the boat has a fish tailing type of motion at the transom at high speeds. SO guys what causes this and how do we remedy it?
Scott
Post by Scott »
Is there a fin..?
Thun.der.bolt
ˈTHəndərˌbōlt
upspirate
Post by upspirate »
Is all the slack taken up out of the steering???If cable,it may have stretched some
maninblack646
Hi I have no fins on the hull yet, also steeering is not a issue its very tight
jamie
Nova SS
Post by Nova SS »
I posted this question on the vdrive site as well to see if we can get some more insight into it and so far the only response asks if the rudder might be loose.
Weight may be a little forward. You mignt try a coulple of sand bags as far aft as you can get them and see if there is any change. At the very least it will be a cheap try.
maninblack646
Interesting thought of having to much weight forward.
Since the seat is at the back of the boat I found no difference with just me driving or with an extra 300 pounds with two passengers beside me.
I'm still of the opinion that I need racing fins and would love to hear from any one who has built the Genrty if they had this same problem.
jamie
Have built the Sherwood Queen, Gentry, 16'cedar strip Whitehall, 16'cedar strip canoe(red bird), 21' Fantail, 15' cedar strip ( prospector canoe )
Jamie,
You didn't mention the other weight /passeger back there with no affect. I would love to see a picture of the attitude of the boat underway. I might think mini skegs aft. But, if you're stern down it could get worse.
Trackhappy
Re: Improving stability of the gentry
Post by Trackhappy »
I am about to embark on a Gentry. Are there any updates or comments on this issue????
What kind of motion are you relating to? :?
A list from one side or the other?
A fishtailing effect?
Chine walking?
Trackhappy
I'd still like to hear more about this issue if anybody has any information. Has anybody else built a Gentry and actually tuned it? :)
66cobra
Post by 66cobra »
What ever happened to this thread? I have watched several utube's of Gentry's while under power and it appears that the hull planes well but doesn't ride high. Being new to this group, I wonder if the motor were farther back would the weight distribution change allowing the nose to come up ....
She would be faster....
Jon
