Improving stability of the gentry
Trackhappy
Re: Improving stability of the gentry
Post by Trackhappy »
I suspect that it is the rather sleek shape that makes it look that way. Most planning boats upper structure tend to rise as you go forward, but Gentry stays pretty much level.
Mirwin
Post by Mirwin »
Jin - did you get any further with her stability questions? I think of starting a Gentry too - but if they are a bit 'cranky' maybe not? Thanks, Murray
Trackhappy
Hi Murray, and Happy New Year. I have only had my Gentry (Brandy) out a few times, and I am by no means an expert but as built to the plans I certainly would have no hesitation in recommending her to you. At 50MPH, I chickened out as it was feeling a little "slippy" from side to side, but that could just have been my lack of experience and a slightly choppy sea.
At idle, she does 5 MPH with good steerage, which is about perfect for tootling around a no wake area, from memory, at 20 MPH you can't see over the bow as it is too high, but not much above that it drops back down and you are in her sweet spot where she really sits flat and shines. The only other quirk is in a sharp high speed turn you get a noise which I think is cavitation. In my haste to get a cheap prop though, I apparently got cupped one, which from what I have since read and learned may be the problem. Haven't had her out since.
All the best,
Glenn.
skyday
Post by skyday »
already braided and tried different pads.. pf and blue i might try a set of cl but on my rx8 they didnt give the kinda performance im after.
Might just jump in for a bbk.
I think euroquip do -2 pipe. anyone tried it?
