electric tug,
My post is to mention the other side of welded aluminium boats, compared to welded steel boats. There are other points of view and there are some very strong market forces that reveal why the difference in the two metals' properties results in a huge market for aluminium boats- both formed and riveted as well as welded; while there is virtually no market for the same boats in steel.
I understand from your post that your don't care for aluminium and less for welding it! And as someone who's designed built hundreds of them, welded by my own hand, we have a point of view difference that may be a gulf that can't be bridged. I have built a couple of steel boats but at 43' and 52' they hardly concern our discussion about small boats here on Glen-L's Forum.
http://www.kastenmarine.com/alumVSsteel.htm this article is by a marine designer and would allow readers of the Forum to research some of your assertions about Alum V Steel and make a detailed comparison of the two metals.
The primary points to consider IMO are that all steel requires painting to a level that will require a decent sand blasted surface other wise; its just a steady march to 'rusting away'-and this includes ongoing maintenance- where Aluminium Oxide is 'self healing' "Ferric Oxide" is not. So the market builds in aluminium for the corrosion resistance provided.
electric tug wrote: ↑Mon Mar 29, 2021 3:16 pm
I think AL. is overrated. Many times I think its used just because it more exotic and novel.
Note that 100% of all jet sleds being mfg'd in the PNW that run rocky rivers; use welded aluminium and not steel? If the steel was preferable- why wouldn't the market of dozens of name builders reflect that? I think your assertions are not really as accurate as some web research might explain?
Cost of material and welding equipment? No question steel is cheaper and welding it can be done with 10X less skill and cost of equipment when compared to welded aluminium... no argument from me. And this is from someone who's owned (and owns) plural 10's of thousands of $ worth welding equipment to weld aluminium.
And if the boat is not pro welded, I dont know if I would trust it under conditions which would stress the hull.
Skill in welding: No argument it takes more hours of practice to produce the level of beads required for a well built aluminium hull than it does for steel. Aluminium welding, both MIG and TIG are much more demanding skills than their steel alloy counterparts but.... I consider this just a matter of practice and skill development. I started in steel stick electrode welding and gradually moved my skills upward to produce acceptable beads on aluminium- anyone with determined practice can do the same.
The welds can crack unless you heat treat them. Especially if running into white water or heavy chop.
As someone who's welded 20k hours of MIG and TIG aluminium on hundreds of small welded aluminium boats: I have never heat treated any welds and they have never failed! Most of my work still fishes commercially (when allowed by government!) and all of them go out in a surf, (bow on) and retrieve 4 to 10x their hull wt in salmon and land that load in a following sea on a gravel beach. All of them are still in service in various Alaskan waters and take whatever sea state is present to do their job. I can't say your quote above doesn't seem based on too much experience with a "heavy chop" as we'd define it here in the Alaskan waters?
Aluminium costs versus steel costs: Aluminium is not proportionally more expensive its
out of proportionally more expensive. However, our 'feelings' about metal costs don't matter: the market wouldn't charge more for one metal over the other if people weren't willing to pay that premium. One metal provides a series of benefits over the other in regard planing hull shapes. So the market pays the premium to get the "superior" product for the benefits those properties offer the specific market niche of impact resistant, light wt. planing hulls.
E'Tug, I guess we'll just have to "agree to disagree" about the two metals? I think the market forces are very important to consider? Mfg's are in business to make money... if they didn't use the metal that was most profitable to their products they'd make less money... and the small metal boat business is 100% (figurative percentage; not exact) made of aluminium. The strength to wt ratio is not in steel's favour, the cost is higher for the "Miracle Metal" but there must be some underlying economic reason for the markets' decision?
I think that reason is that, all considered, marine alloys for welded planing boats, and stretch forming alloys for riveted boats are all more profitable and economically viable using aluminium over steel.
Cheers,
Kevin Morin
Kenai, AK
