2 Berth Classic Barrel Back
Hoppoz
Post by Hoppoz » Tue Jul 22, 2014 9:40 pm
I'm looking to build a Classic Barrel Back but would like to include a forward 2 Berth cabin along the lines of the Bravado deep Vee Overnighter.
Is this possible and has anyone done this before?
Thanks
Re: 2 Berth Classic Barrel Back
Post by Bill Edmundson » Wed Jul 23, 2014 5:15 pm
Hoppoz and Cossyboy
I can't recommend these drastic changes to the base designs.
I have seen the Yon'e 22. You can't call it a Tahoe in any respect. Instead of a negative 30 degree transom it has a positive 14 degree transom. The transom is much wider and deep vee. Not a shallow vee. I never saw it running on the water. So, I don't know about performance.
A BB with a berth would require probably a Monte Carlo or a Miss Chris to be big enough. You will probably need to give up half of the front cockpit to make room. Again, going to a deep vee changes the running hull.
I would suggest, that you find a hull design that you like and change it above the waterline.
tug
Post by tug » Fri Jan 23, 2015 3:30 pm
I know this is an older post, I came across a picture of a 1929 Chris Craft Sedan named "Topper". I think this is one of the coolest barrel backs I have ever seen, and might fit the bill nicely for the OP.
tug
