Double Eagle 23
Albert
Double Eagle 23
Post by Albert » Thu Aug 20, 2015 7:09 pm
A buddy of mine is interested in building a lobster boat.
Now I've referred him to the Double Eagle 23 but also the Outerbanks 24 from B&B.
Due to his tight budget I've opted to go with the 23 knowing it will save costs on epoxy/fiberglass.
Now the question is; I've noticed that the 23 can be extended but is it possible to build in an engine bracket that is able to carry a 150 hp engine.
Will this boat be able to carry the weight ?
Regards,
Albert.
Ps: I know that 150 hp is unnecessary. I'd prefer a 70 or 90 but it's not my boat.
Re: Double Eagle 23
Post by Bill Edmundson » Thu Aug 20, 2015 8:01 pm
It will carry the weight.
Re: Double Eagle 23
Post by kens » Fri Aug 21, 2015 12:06 am
If you do go that route, then be sure to put lift strikes on it, it will get up and fly!!
Albert
Re: Double Eagle 23
Post by Albert » Fri Aug 21, 2015 4:27 am
Thankyou guys, I appreciate the replies. :)
Should I leave the transon like in the plans or should I make it a bit thicker ?
