Bolero wake boat
miltieb
Bolero wake boat
Post by miltieb »
I'm thinking about building a bolero and modify it into a wake boat. I did some drawings and was wondering what people's thoughts are.ImageImage
Re: Bolero wake boat
Just my opinion, but wake boats should be banned or regulated. When they come out, I have to go in to shore because the chop is too much to pound through. Not trying to start a controversy here, but just know there are other people trying to enjoy the water too.
It would be an interesting problem to integrate water tanks and the pumping system.
The Bolero hull would probably do the trick and would most likely be big enough to handle the water tanks. The bow modifications in your drawing would be a big challenge in plywood though and I don't really see the reason behind them other than to copycat the production wakeboats out there. It's easy to modify the inside of the boat. Another challenge altogether changing the hull like that. It would basically be a completely new design.
How much is a wakeboat these days? 70k? You could probably build a nice Bolero for 30 ish?....???
JimmY wrote:
Thu Jun 11, 2020 5:31 pm
Agreed,
Gosh, why would you take a perfectly good boat and upset the weight/balance to the point it throws a ugly wake??? it makes no sense.
If you wanna play with your boogie board, then go to the ocean where the waves are.
The rest of us want to use the calm water.
miltieb
Post by miltieb »
hoodman wrote:
Thu Jun 11, 2020 7:12 pm
the bow modifications are for wider seating in the front and they keep the original hull design its pretty much just pieces stuck to the sides so the seating area can be wider.
and a good wakeboat these days is well over100k
miltieb
Post by miltieb »
I did a 3d model of the hull and the actual hull portion is pretty much identical to the hull of the bolero
Post by vupilot »
You ask for peoples thoughts on a wakeboard boat using the Bolero as a starting off point then report them for their thoughts on wakeboats? Yeah, a lot of us aren't fans of them around us. Wakeboats are indeed fun but they also make the water unpleasant for the classic designs that share the water with them and a lot of the operators are not courteous or even aware of their surroundings and often put small boats in compromising and dangerous positions they cant avoid.
I agree with Hoodman, with such changes youre basically making your own design at that point. I'd like to see it done, it would be a neat challenge and a more interesting, more unique and less expensive boat than factory built. Give it a go. Just be one of the courteous wakeboard boat captains out there when youre done.
Aussie
Post by Aussie »
Hi
I really like your idea.
I have never looked at wake boats until I found Pavati
I am also looking at building a replica of the Pavati and was thinking about buying the Bolero plans and making the changes to have the appearance of a Pavati but with my own twist.
I will be doing aluminium for the build.
Design phase at this point
