Squirt Update
pamelalynne1
Squirt Update
Post by pamelalynne1 » Thu Jul 14, 2011 2:49 pm
Finally, almost finished. The seats came this afternoon, so I "just had to" install them. :D I'm wondering if they're overkill; but they are comfortable. In the next few days I'll be getting a trailer to fit and then registering the boat. Looking forward to the launch.
areame
Re: Squirt Update
Post by areame » Thu Jul 14, 2011 4:59 pm
Looks great! I'm jealous you're so close to launching ha. What else do you have to finish besides the registration and trailer?
pamelalynne1
Re: Squirt Update
Post by pamelalynne1 » Thu Jul 14, 2011 5:20 pm
UM... I need to connect the choke cable and fasten the throttle control and switch plate to the side panel. I want to get black screws to match the switch plate. :D Besides, I'm spending most of my time working on the Stiletto. I'm hoping to finish that in the next month or so and get it sold. I need the money for the next build. The great thing about working part time and having 4 days a week for the boats is I can get a lot done quickly. It is a bit scarey building the Stiletto on speculation. That's why I didn't just jump into building a Monaco, Barrelback or Tahoe.
pamelalynne1
Re: Squirt Update
Post by pamelalynne1 » Fri Jul 22, 2011 7:49 pm
I "launched" the jet boat tonight about 8 PM. I needed to switch trailers, so I thought I'd see if it would float. I had started it it for a couple of minutes in the yard; but it wouldn't keep running when I tried to take it for a little spin. I checked the manual and the only thing I can surmise is tha
t it is a problem with the rpm limiter. It is supposed to have a return line to the fuel tank that runs through a limiter valve. I had tried to isolate it as I don't have a return fitting on my fuel tank. I had plugged it into the module and just plugged the outlet. Not all models had this limiter and I'm wondering if I can just eliminate it altogether.
I also haven't gotten the ski tow cleat I ordered. It was out of stock. I might just get another Perko cleat to match the bow. I'm glad the water is calm where I docked her. I wouldn't want to lose my stern light.
It does look cute alongside the big cruisers on the river. :D
Re: Squirt Update
Post by Roberta » Sat Jul 23, 2011 1:57 pm
:D Congrats!!! Have fun with your new toy!!
Roberta :D :D
pamelalynne1
Re: Squirt Update
Post by pamelalynne1 » Sat Aug 13, 2011 3:28 pm
I finally had some time today after working on the Stiletto to take the Squirt out and play with the high speed jet. Ther trouble is, the faster I seem to go the less the speedometer wants to register. I'm thinking the angle of the pitot is off as most transoms are slanted 15 degrees and mine is perpendicular. Lots of fun though.
BulldogBoater
Re: Squirt Update
Post by BulldogBoater » Sat Aug 13, 2011 9:08 pm
Mine has the same problem. I think it might be because at high speed the tube is hardly in the water as I skip along the chop. I'll be changing to a GPS speedo.
KB
Return to “Jet Ski Power”
