Dyno Jet [Building started at 10-05-2012]
SeaPea
Re: Dyno Jet [Building started at 10-05-2012]
Post by SeaPea »
Nice work Speedy!
Craig
SUP
Riviera
Scubaru Steve
Post by Scubaru Steve »
any idea what your all up weight will be? also can you measure the total size of the seating area? how much width is there? im planing to use 2 racing seats for style and comfort, also for low mounting ability.
Speedy
Post by Speedy »
Steve I'am a little busy with other projects (home :) ). Tomorrow i wil measure the seat for you.
The hull is not heavy we can turn him easy with two people. The engine is about 75 Kg so i guess total weight shall be around 150 Kg
Greetz Speedy
Greetings Paul
Speedy
Post by Speedy »
It's 106 cm thats about 42 inch wide
Greetings Paul
Scubaru Steve
thank you!
sawyer
Post by sawyer »
Hey nice job on the boat do you have any pics of it finished?
Speedy
Post by Speedy »
sawyer,
i had a break and just started to go further. Top deck is glassed now and busy with sanding on the bottom. When i am there i will make some pictures of it.
Greetings Paul
crowsridge
Post by crowsridge »
Progress pictures are great too! You don't have to wait until its done. :D
Speedy
Post by Speedy »
Some progression :)
Greetings Paul
Speedy
Post by Speedy »
Starting with the deck
Greetings Paul
Speedy
Post by Speedy »
I used white oak 8 mm thick and 44 mm width. The edge is 8 mm thick and 80 mm width
Greetings Paul
Speedy
Post by Speedy »
I turned it now and painting the hull.
1st layer of primer (International Pre-Kote)
Greetings Paul
Speedy
Post by Speedy »
Second layer 50% pre-kote and 50% paint
Greetings Paul
Speedy
Post by Speedy »
Sanding that layer and the third layer 100% paint
Greetings Paul
Speedy
Post by Speedy »
Sanding third layer and did some putty for the weak spots
Greetings Paul
Return to “Jet Ski Power”
