Another Jet Squirt is born.
fourspeedfish
Post by fourspeedfish »
Hello all,
I finally started last month on my version of a jet squirt. I have been reading as much as i can for the last year or so. I imagine i will have many questions.
I have a 96 seadoo 720 just begging to be cut up and repurposed into a classic looking boat. Attached are a couple pictures of the frames. So far i have about 2 hours into building the building form and about 22 hours into the frames.
As i post progress pictures, i ask everyone to please point out anything that looks funny, not quite right, a little off, or just plain wrong.
This is my first wooden boat build an i welcome all comments.
fourspeedfish
Re: Another Jet Squirt is born.
I sorta just guessed at the shape of the top of the transom.
Pullie
Post by Pullie »
I will follow this thread closely, i just picked up my dornor kawasaki 550 and have themplans for a flying saucer, i will put the fs on a diet and see if i can get her to fly :D
Good luck with the build!!!
Ronb172
Post by Ronb172 »
I wish I had made my form higher. I'm going to flip my boat to install the sheers. I'm old and with this colder weather, I just don't bend well anymore....lol
Building my third SUP.
Started the Topper build.
fourspeedfish
Pullie wrote:I will follow this thread closely, i just picked up my dornor kawasaki 550 and have themplans for a flying saucer, i will put the fs on a diet and see if i can get her to fly :D
Good luck on your build as well. Keep us updated
fourspeedfish
Ronb172 wrote:I wish I had made my form higher. I'm going to flip my boat to install the sheers. I'm old and with this colder weather, I just don't bend well anymore....lol
I added 11 inches to the Form. Just enough to raise it up off the floor some and still be able to reach the center without a big stretch.
fourspeedfish
A little more progress. Steamed the first laminate of the sheers. You can see the 4 inch pipe in the left side of the picture that i used. A wallpaper steamer in one side and a garment steamer in the other side for an hour and a half. I will fit them after they sit over night.
Ronb172
Post by Ronb172 »
Looking good fourspeedfish. I just glued my first sheer laminate today. Great feeling when it start looking like a boat...
fourspeedfish
Ronb172 wrote:Looking good fourspeedfish. I just glued my first sheer laminate today. Great feeling when it start looking like a boat...
Thanks. The sheers really start to define the boats shape.
fourspeedfish
Hello all,
I have the sheers epoxied in place. Now i am now working on fitting the chines, which seem like i have spent a lot of time.
Does the sheer / stem joint look correct?
And how do the chines look? Even with me putting a lot of twist in them i cant see how they will ever fair correctly without adding additional material to the bottom.
Thanks
Post by gdcarpenter »
From what I see it looks like you will likely 'fair away' most of your outer sheer lamination by the time you get the stem leading edge faired to match the angle where the sheers meet forward.
Ideally the sheers outermost edge should have been 'set back' from the front of the stem to allow for the fairing of the stem. Wonder if you could epoxy on some material to the front curved edge of the stem so you don't have to fair away so much of your sheers.
Ronb172
Post by Ronb172 »
I'm fairing my Squirt now and it looks a lot like yours. I'm not sure how you'd do it any other way unless you changed the shape of the breasthook. I have shaved off a lot of my sheer but I think it's coming along fine. This is my first boat so I don't really have a eye for this yet.
The forward edge of the stem should be bevelled to match the angle the sheers hit the stem, this is to support the plywood where the two sides meet in the front, hopp this helps clarify things a bit.
areame
Post by areame »
Fourspeedfish, when I faired my sheers I ended up having to take quite a bit off. I used a 6" wide piece of scrap plywood to test the angle from the sheer to the chine. You want to make sure the mating surfaces have full contact with the plywood, so when you begin planking there's a snug fit.
fourspeedfish
Thanks everyone
Most of the pictures i have seen of the sheer / breast hook joint look just like i have, but it seemed like i would fair away most of the sheer. I think i will laminate a piece on the stem like gdcarpenter suggested. That way i would not have to fair all my sheers away.
Return to “Jet Ski Power”
