turbo subaru dyno jet with cored hull
electric tug
Post by electric tug »
Hi, I am starting a dyno jet build.
two things that are going to de different with this build:
1. Im using a 1/2" core rather than Aluminum or wood. wood is far too weak for river travel.
also weight is a consideration. A carbon fiber/kevlar hull, costed out is less money than buying a new welder, learning to weld, buying the special feed gun, the wire, the electricity, and the Aluminum which after cutting about 1/4 of all the AL is scrap.
The Carbon fiber and kevlar gives amazing abrasion and impact resistance. I know. I have been experimenting with this for years.
the honeycomb, simply bends/deflects to the Impact(rock), it is not rigid, and allows for deflection. Its not perfect, of course, but Aluminum will hole too, no material is perfect. I have seen demos where Aluminum will fail, before a cored hull will.
Finally, the weight saved. I am guessing the hull in core will be about 1/3rd less than a wooden hull, and certainly far less then an Al hull. This gives me more allowable weight for a bigger engine.
2. I wont be using a standard jet ski. This boat is essentially a jet sprint. new Zealand Sprints usually have v 8's in them and the standard sprint is 13 ft long. by 5 ft wide.
My engine of choice comes from a subaru, are cheap , readily available and will likely mate to a standard stx jet pump or maybe even (im hoping) with a Berkeley or dominator jet drive. The EJ20 DOHC Single Turbo Power output ranges from 197 bhp (147 kW; 200 PS) @ 6000 rpm and 260 Nm for the GT to 220 PS (162 kW; 217 bhp)
I am concerned about room for the engine, but it will e easy to just extend the transom area by a foot or so IF necessary.
The core is 1/2 inch Nida core. using 1 layer of woven cloth each side, 1 layer CF, 1 layer kevlar 1 layer cf.
I will have to do some alterations. But in general, This should be a very peppy boat with easy to find parts.
wish me luck. core ordered yesterday...
electric tug
the first challenge
HI, If any one out there is reading this, I came across the first hurdle today. (Of Many Im sure).
I now own 7 sheets of 1/2inch Nida core.
arrived today.
But there is a slight issue;
Nida core, in all thier wisdom (or greed?), does not make 4 x 8 sheets of core. Nope!, they had to break from tradition and make
4 ft x 7 ft sheets...
so, how does that affect my build? its messes with my glen-l patterns, which are developed for 4 x 8 sheets of ply.
so thankfully there is a solution. First I have to cut a 4 x 7 sheet in half and epoxy it together to make one long 14 ft x 2 ft sheet.
then I can trace the patterns out onto that to cut it. It will get the same effect but the joint will not be at the same place as on the patterns. I dont see any huge issues tho.
Ill post some pics to explain it.
gap998
Re: turbo subaru dyno jet with cored hull
Post by gap998 »
Your video is showing as private on the link.
Gary
garrech
Post by garrech »
Same here, can't view.
Return to “Jet Ski Power”
