Dynojet tnt
flabio
Dynojet tnt
Post by flabio » Fri Jan 04, 2008 10:31 pm
What are the differences of a dynojet boat vs a jet powered TNT,Squirt or bullet. I am considering building a jet boat and these 3 look a lot alike
marksa1458
Post by marksa1458 » Mon Jan 07, 2008 8:51 am
The DynoJet is specifically designed for a jet unit taken out of a jet ski. Most folks who put a jet unit in another design are converting an outboard design.
It should be noted that there is a lot of design/fitting work on the part of the builder in any jet design - mostly because each jet ski manufacturer incorporates a different setup.
Many of the Squirt builders extend the jet unit out of the back of the boat which may contribute to porposing... I say may because many builders have had very successful builds without this condition and any builder putting a jet ski setup in a boat should consider this issue before fitment of the intake and engine...
Both the below websites detail my build progress.
http://dynojet.fateback.com/Index.htm
or
http://www.geocities.com/marksa1458/
Return to “Jet Ski Power”
