Dynojet boat
flabio
Dynojet boat
Post by flabio » Sun Jan 13, 2008 9:10 pm
I am thinking of building a Dynojet over the winter and was wondering if you could use a Rotax motor out of sea doo boat I found one on craigslist and wasnt sure if it would work some I am checking before buying the motor and jet
marksa1458
Post by marksa1458 » Mon Jan 14, 2008 6:39 am
You can use any powerplant from any jetski. You will just need to incorporate the specific design into your hull. Currently, there is not a lot of advice/guidance on this forum about powerplants from SeaDoos, Yamaha's or Polaris jetskis.
Kawasaki's have been the most commonly used, so there is a lot of advice/guidance with the kawasaki setup. Probably, becuase of their abundance on the market and availability of parts. I used a 650cc Kawasaki Engine from a Kawasaki x2 and a driveshaft from a Kawasaki TS. I would have to dig up of the exact number, but using the shorter driveshaft (which has the same coupler and spline as Kawasaki x2) I was able to save about 11" of length.
Take a look at the below pics for an idea:
or
seraulu1
Re: Dynojet boat
Post by seraulu1 » Mon Mar 22, 2010 3:49 am
marksa1458 wrote:You can use any powerplant from any jetski. You will just need to incorporate the specific design into your hull. Currently, there is not a lot of advice/guidance on this forum about powerplants from SeaDoos, Yamaha's or Polaris jetskis.
Wow these is nice!!!
Return to “Jet Ski Power”
