It is currently Wed Jun 19, 2013 5:31 am
Post new topic Reply to topic  [ 4 posts ]
 Post subject: SeaDoo going to premix
PostPosted: Tue Jul 21, 2009 6:46 pm
I am getting to the point where I might actually consider possibly doing a shakedown on the jet Squirt. I have the SeaDoo 580 white motor and have removed the oil injection and am running premix.
Question is: Do I still need the oil tank for lubrication of other components of the engine - mainly the bottom end - or can I axe the entire setup? I have little to no knowledge of these motors but I do have the manual.
KB
Squirt Build: http://www.tubbytug.com/SquirtHome.html
PostPosted: Fri Jul 24, 2009 7:58 am
I don't know the correct answer to the question, but someone at the following link should. They cover a lot of PWC's and it quite active.
You have to register on the site to post. (free)
http://www.pwctoday.com/
Waren
PostPosted: Fri Jul 24, 2009 9:35 pm
Once you switch to premix all that plumbing can leave.
Just be sure you have capped off all possible vacuum leaks on the intake, or you will get a lean run, and squeak it. Secondly be sure you have plugged the impulse/case-pressure line to the pump.
The bottom end is lubed by fuel/air intake charge.
PostPosted: Wed Jul 29, 2009 8:39 pm
What about lubrication for the rotary valve in the SeaDoo? The lines seem to supply oil to the rotary valve?
Any thoughts?
KB
