New member from oregon
joshuab
Re: New member from oregon
Post by joshuab »
boat21 wrote: windshield, gas filler cap, cockpit combing?
Fantastic Job, on the boat and documenting it! Always eager to see your next video.
Thanks
B
Thanks for the compliment, yes on the windshield, yes on the fuel fill cap, also adding step pads, cleats, bow rope guides etc. I built a stainless cutwater and transom bands as well, the zip will be dripping in "bling" not sure about a cockpit coaming yet, i also like the crash pad surround idea, too early to tell just yet. I just finished uploading this months video to youtube tonight.
joshuab
Post by joshuab »
Jimbob wrote:Josh,
That looks fantastic! I hope my deck looks that good once it is sanded.
Thank you for the kind words, your deck will be beautiful, i am positive of that.
joshuab
Post by joshuab »
Hercdrvr wrote:Your boat looks very nice. Such a fun part of the build.
Thanks Matt
joshuab
Post by joshuab »
Built another painters shanty, stuffed a couple heaters inside and rolled on the first epoxy coat this morning, as soon as it greens up i will roll on another, the weather has nothing on me :lol:
Joshua
She looks great! Sure is fun when you get that first clear coat on and you step back! You think, "DAMN! I did that!".
jenko
Post by jenko »
looks fantastic Josh
joshuab
Post by joshuab »
Thanks Bill, Jenko, today i sanded the deck and edges smooth with 80 grit, wiped it down with denatured alcohol and taped it off for the second epoxy coat tomorrow morning, should smooth out quite a bit with the second coat. 8)
joshuab
Post by joshuab »
Second coat on the deck. 8)
BarnacleMike
Post by BarnacleMike »
Looking great, Joshua!
joshuab
Post by joshuab »
Well today i filled the rear deck seams with a mixture of micro balloons and poxy shield, 6oz of epoxy added to 6oz of micro balloons gives me a bright white, easy to sand seam with the consistency of toothpaste that can be buried in top coats of epoxy (forever seam) i used a cake decorating bag with a 1/4" round tip to pipe the mix into my seams, worked out really well, the seams need sanded flush as there are a few places where the epoxy mix seeped out of the groove, it looks a little sloppy right now but when sanded flush should produce perfect straight seams. Making good progress. 8)
jenko
Post by jenko »
nice work josh
Post by vupilot »
Sweet! Looks like satisfying work. Except the tape work looks tedious.
Moving right along. This is the same sway I did my caulk lines, and it works pretty well and looks good.
mattmays
Post by mattmays »
Your video series on You Tube brought me to this site. Just want to thank you for all you've shown on "building the Zip"
Bam!
JoeM
Post by JoeM »
joshuab wrote:Well today i filled the rear deck seams with a mixture of micro balloons and poxy shield, 6oz of epoxy added to 6oz of micro balloons gives me a bright white, easy to sand seam with the consistency of toothpaste that can be buried in top coats of epoxy (forever seam) i used a cake decorating bag with a 1/4" round tip to pipe the mix into my seams, worked out really well, the seams need sanded flush as there are a few places where the epoxy mix seeped out of the groove, it looks a little sloppy right now but when sanded flush should produce perfect straight seams. Making good progress. 8)
That looks great! Another poster mentioned a youtube series you're doing, about your build? You should put your link in your signature so curious folks like myself can find it and watch. :)
