New Member from NJ
richarts
New Member from NJ
Postby richarts » Tue Sep 20, 2016 6:48 am
Hi to All,
I am just starting on the Monaco Utility version. I have a couple of questions about the stringers. Are the 2x6 stringer dimensions in the plans nominal or actual? Looks like the dashed stringer end view pattern on the transom plans is 5 1/2 x 1 1/2 indicating that the given 2x6 dimensions are nominal. How about other dimensions in the plans; are they actual or nominal?
Also is there a preference on the stringer wood, e.g. doug fir or mahogany?
I look forward to the Glen-L building experience. I have build several other boats including Harry Bryan's Bessie and Rambler. I also built Ted Brewer's Capecod Catboat ( I think a picture is still on his website).
Re: New Member from NJ
Postby DrBryanJ » Tue Sep 20, 2016 7:55 am
Hi Richarts:
Welcome to the forum. What part of NJ are you from. I'm from Pompton Plains. I believe the dimensions are nominal, but since my boat doesn't have stringers I can't say for sure. I'm sure someone that has built a boat with stringers will chime in.
Postby hoodman » Tue Sep 20, 2016 7:58 am
All dimensions nominal, as you say, unless noted as "net" in the plans. So for instance on my boat the chines are supposed to be "net" 1 inch so I had to laminate a 3/16" strip onto my 1" (milled to 13/16") lumber.
richarts
Postby richarts » Tue Sep 20, 2016 9:18 am
Thanks for the feedback on the dimensions! I live in Mountainville, NJ. It is between Califon and Oldwick.
