Double Eagle 23' - SKEG
Gaucho
Postby Gaucho » Sun Oct 08, 2017 12:19 pm
Hey Guys
My name is Rick, from South Brazil.
Im building a double eagle 23' and this is my first boat construction experience. I work as a cabinet maker, so wood work is not a problem for me.
Actually Im finishing the bottom planking and need to decide about the skeg.
For you guys, that have more experience in boat construction, can I built the skeg with a solid wood member, avoiding lamination ? I have a big piece of wood that I can use to do it. I will use a inboard motor.
What do you think about that ?
Regards
Rick
Re: Double Eagle 23' - SKEG
Postby hoodman » Sun Oct 08, 2017 3:28 pm
Rick, great to hear from you. That is an awesome looking boat so far. Looks like you are doing a great job. I hope you will consider continuing to post about it here on the forum.
I don't have a definite answer for you on the skeg but it seems to me that it should be as stable as possible since you'll have a shaft running through it. If the plans call for a laminated skeg that could be one of the reasons. Or they just assume that most wont have access to a timber big enough and high enough quality to make it out of one solid piece.
There's lots of folks here that will know better than me, fortunately for you!
Postby kens » Mon Oct 09, 2017 6:05 am
I would be afraid of checking or cracking in a large one piece like that.
Laminations are more stable as far as checking and cracking. Laminations are shown on the plans, correct?
Postby Bill Edmundson » Mon Oct 09, 2017 6:36 am
That would be one long hole to drill and seal. And as Ken said, I'd be concerned about checking and warping.
Gaucho
Postby Gaucho » Mon Oct 09, 2017 8:42 am
Thank you so much for the answers guys.
Checking and cracking is a point that I wasn't consider. You are completely right !!!! I will follow the plans and make a lamination skeg.
And cheers Hoodman, is gonna be a pleasure post more pictures as the work progresses.
Thanks a lot.
regards
Rick
