Newbie and little confused
BigDaddy
Postby BigDaddy » Thu Dec 18, 2008 6:07 pm
Just purchased tubby tug...trying to cut parts and got confused on sides...are they supposed to be cut "curved" on top and bottom or staight across on bottom??? :?
John K
Postby John K » Fri Dec 19, 2008 6:32 am
Welcome to the forum. I am sure you will get an answer on the tub. There were 2 at the Gathering this year.
upspirate
Postby upspirate » Fri Dec 19, 2008 7:30 am
Go by the patterns...the sides have a curve to them as they bend around even though they may appear to be straight lines.
Welcome also :D
BigDaddy
Postby BigDaddy » Fri Dec 19, 2008 11:08 am
Thanks...didn't know if that was a mistake on the bottom side of blue prints or not. Thanks again.
upspirate
Postby upspirate » Fri Dec 19, 2008 2:06 pm
Sorry for the short answer this morning...I was tired.
The panels are cut with a curve so that as they bend around the bottom(or shear,or any other piece they meet)& get wired together(in the case of stitch and glue),they will create the shapes as designed.
This also happens when the bottom pieces meet at the keel & stem on other designs.Aft where the bottom is flat,the pieces are straight where they join in the center.As you go froward to where the keel & stem make the curve,the panels edges stop being straight & you have to cut them on a curve to meet the centerline.
Hope this helps!!! :wink: :D
