I'm needing to slide the round 'kranse iron' or 'eyeband' in the photo onto the last 6" or so of the square bowsprit (3.5" X 3.5" Doug Fir).
The ID of the kranse iron is 2.25", the bowsprit is 7' long.
Needing to know how to make a 'square' member into a partial 'round' member...?
I'd like to be precise, meaning I'd like to finish with a truly 'round' 2.25" on the forward 6" of the 'sprit.
Any ideas on how to go about it??
MW
How to make square into round...?
Re: How to make square into round...?
Its not that hard. You just knock off the corners until you get it round. Start with an octagon, then turn it into a 16 side, then 32. After that its pretty easy to blend
Another approach if you have a quarter round shaper bit of the right size...
https://www.woodcraft.com/media/W1siZiI ... fae9c93276
