I thought I would share some (small
It took a whole lot of sanding and epoxy to get her faired! and she still not perfect but its as fair as I an get it...
I just rounded over the chine and added a healthy fillet to the skeg so the fiberglass will manage the transitions around the corners.
I also just rolled on an encapsulation coat of epoxy over the whole boat. I had test rolled a small section and then tried to sand it and noticed that the sandpaper gummed up right away. So I scrubbed it with dish soap and a scotch brite pad and it got rid of the gummyness. My first run in with amine blush.
Questions: (I had a whole ton of questions until I re-re-read the Glen-L book section on fiberglassing and "How to fiberglass boats" by Ken Hankinson).
How many coats of epoxy encapsulation do you put on before you lay the fiberglass? Is one enough? Note that I used the west marine roller to apply the epoxy.
The transom will stay bright. Do you fiberglass a bright transom? I see in the glen-L book that it says that it will be transparent so it may be a good idea. How do you handle the fiberglass overlaps in this case?
They mention stapling or taping the fiberglass to keep it from moving around when applying the epoxy, what is preferred? I imagine the staples are hard to remove later?
Any other tips before I get started? I don't want to screw it up!!!
