Mast rake for a glenL 14
Posted: Wed Jan 10, 2018 4:46 pm
by Levaggik
i purchased an aluminum mast for my GlenL14. I need to cut a block at the proper angle to rake the mast to 4". I am supposed to level the hull. What part of the boat do I put a level on to confirm the hull is level? The sole, the seats, the centerboard trunk? ??
Re: Mast rake for a glenL 14
Posted: Thu Jan 11, 2018 8:42 pm
by JoeM
Im not familiar with the plans. Was there a set up level as you built it called out in the plans? If so i'd use that.
Posted: Fri Jan 12, 2018 8:43 am
by JimmY
Typically, the top of building form is the level line. If this is the case, reference the point on the frames that sat on the building form.
