Mast head sheaves and halyards
Stuart
Post by Stuart » Wed Feb 14, 2018 7:24 pm
For the Glen l 25 which is a masthead sloop with a main sail and a jib, how many sheaves are in the mast head? On the drawings for the wooden mast it shows two. In the Glen-L kit they give you 4 for the aluminum mast. Some show 2 pulleys for the jib but I only see one for the mainsail. I was given two fairlead pulleys for the out leds of the internal halyards on the mast. Suggestions are acceptable.
Stuart
Gayle Brantuk
Re: Mast head sheaves and halyards
Post by Gayle Brantuk » Mon Mar 19, 2018 9:50 am
There are 4 sheaves in the Masthead fitting for our "C" spar...
Stuart
Post by Stuart » Tue Mar 20, 2018 9:51 am
Hi Gayle, thanks for the reply but just one question more, are the four sheaves used or are some used as spacers. Thanks for any clarity, I want to get this project into the water this spring..
Stuart
Gayle Brantuk
Post by Gayle Brantuk » Wed Mar 21, 2018 8:14 am
The sheaves are inserted into the Masthead "C" casting next to each other with a piece of micarta or plastic between. Scroll down to the section on this part in our Spar Instructions: http://www.glen-l.com/designs/sailboat/ ... tions.html
Return to “Sailboats”
