Carriage Bolts ?!?
Mike Worrall
Carriage Bolts ?!?
Post by Mike Worrall » Tue Feb 20, 2018 11:57 pm
The image below is from the plans for the 29 foot Francis Drake FG version, specifically the detail for the bulwark cap.
Note that the 1 X 3 cap is secured by an inner and outer 1 X 2 'shear cleat', and that the plans say to attach these cleats with 5/16" 'Carr. Bolts' at 6" intervals? I assume that 'Carr Bolts' means 'Carriage Bolts'.
Really?!?
This seems like a very odd choice; while the 'head' of a carriage bolt would be almost flush with the cleat is was securing, the opposite end - the threaded end - of the bolt would have an exposed washer/lock washer/nut that would be 1) Ugly and 2) Just waiting to snag lines, ankles, toes, etc. As the length of each (P&S) bulwark is over 30 feet, that would amount to 120 exposed bolts / nuts / washers...
Seems to me a much cleaner approach would be to use #12 wood screws at 6" intervals, countersunk to allow for a plug to cover the screw head.
Can anyone suggest why a carriage bolt would be the best way to do this?
MW
Re: Carriage Bolts ?!?
Post by hoodman » Wed Feb 21, 2018 6:04 am
I'm no marine architect but that carriage bolts do seem like overkill for this application. Not to mention that would be horrendously expensive if you used Si Bronze.
Stuart
Post by Stuart » Wed Feb 21, 2018 10:31 am
Nothing holds better than a carriage bolt. That's only two bolts per foot...you sure that would be enough.
Stuart
NAMEngJS
Post by NAMEngJS » Thu Feb 22, 2018 7:10 am
You could use a forstner bit and recess the nut end as the sheer rail is 1" thick you should have enough strength left if you recess the nut, this would provide relief from snags.
Dont know if the cap rail is epoxied down as well but for commercial vessels like tug boats, for example, the fenders are usually bolted in place as these are items that are replaced often and it is easier to remove and replace and those are usually bolted at 12" spacing (Though they use larger bolts).
-Juan Suarez
steveh41
Post by steveh41 » Thu Feb 22, 2018 9:02 am
I believe the intent is to through-bolt the cleats to the sheer which is by far the most secure way to fasten them. In place of expensive bronze carriage bolts I have used bronze all-thread cut to length with a washer and nut at each end recessed with a Forstner bit just enough to make it flush on both surfaces. The unit is then bedded in thickened epoxy to fill the threads and finished smooth on the outside with epoxy putty. The holes disappear and the cost for threaded rod is a lot less than equivalent bolts.
PS- Fastening the cleats also appears to reinforce the hull-to-deck joint which would explain the stout construction.
Post by hoodman » Thu Feb 22, 2018 11:07 am
Good call on the threaded rod.
Return to “Sailboats”
