Gauge lights
csaggio
Gauge lights
Postby csaggio » Thu Feb 23, 2012 7:14 am
I have purchased a 3 position (Off, On, On) switch for my anchor light and bow light. Is it common practice to wire the gauge lights with the anchor light pole on the switch, or is a seperate switch for the gauge lights a better option?
Thanks, Chris
Barrelback19
Re: Gauge lights
Postby Bill Edmundson » Thu Feb 23, 2012 7:27 am
Chris
I'd wire with the running lights. If you're under an anchor light you normally don't need to see the guages.
Soloboat
Re: Gauge lights
Postby Soloboat » Thu Feb 23, 2012 7:30 am
That is exactly what I did I figured that I would need navigation lights at night so gauge /panel lights would be on at the same time. At anchor I could the switch off panel lights and port & starboard lights and leave anchor light on. I don't know if there is any specific rule regarding this setup, I think it is fine if you stick to good wiring practice.
Re: Gauge lights
Postby gdcarpenter » Thu Feb 23, 2012 3:46 pm
I'm an oddball. I have my gauge lights on a separate switch. It is not uncommon for me to make night trips and on those trips I navigate primarily by viewing the outline of the surrounding hills to determine where the shoreline is. I find having the gauge lights on diminishes my 'night vision' and makes it harder to navigate so I have my gauge lights on there own dedicated switch. Otherwise I wouild run the gauge lights with the bow or NAV light.
upspirate
Re: Gauge lights
Postby upspirate » Thu Feb 23, 2012 3:59 pm
Good point GD,Even red gauge light can mess up night vision in really dark areas
Trackhappy
Re: Gauge lights
Postby Trackhappy » Thu Feb 23, 2012 4:08 pm
I think the ultimate would be gauge lights on the running lights but with a dimmer in the circuit. Wonder if they are available?
Re: Gauge lights
Postby Bill Edmundson » Thu Feb 23, 2012 6:52 pm
Your gauge lights are on one circuit. It should be simple enough to put a reostat between the switch and the first gauge.
Trackhappy
Re: Gauge lights
Postby Trackhappy » Thu Feb 23, 2012 7:37 pm
Dimmer - Somewhat expensive....
http://www.westmarine.com/webapp/wcs/st ... sNum=50557
Great price but you would have to find a nice way to mount it or separate the pot from the board.
http://ledshopper.com.au/8a-12v-dc-dimmer.html
I should perhaps mention that there are different dimmers for normal (incandescent) bulbs as opposed to LED ones. Modern gauges may use LED so check first.
LED one cheap...
http://www.ebay.com.au/itm/LED-Dimmer-1 ... 5ae52bcfed
LuisSim
Re: Gauge lights
Postby LuisSim » Mon Aug 26, 2013 4:28 am
csaggio wrote:I have purchased a 3 position (Off, On, On) switch for my anchor light and bow led lights. Is it common practice to wire the gauge lights with the anchor light pole on the switch, or is a seperate switch for the gauge lights a better option?
Thanks, Chris
Barrelback19
i dont think it is a common practice as I never did that..There is some other way to adjust gauge lights..
