1/0 wire
1/0 wire
Post by chugalug »
is 1/0 wire big enough for primary from battery 7 ft for'ward to 150 amp breaker ,then another 7 ft to for'ward busbar? :roll: Was looking for 0 size but had to go bigger.
lakeracer69
Re: 1/0 wire
Post by lakeracer69 »
Try a welding supply house. The ground wires for MIG/TIG welding are in that size range.
Re: 1/0 wire
Post by chugalug »
:D Am using size 2 welder ground wire for common ground to forward busbar.wanted bigger red for primary.site I was looking at ,mentioned 0.thought 1/0 would work.just don't want to have problems.Curious what Bill used on his Bartender. :D
Re: 1/0 wire
It depends on what you are powering but I would hope so!
Re: 1/0 wire
According to the calculator on bestboatwire.com, 150A over a 14ft run on this size wire will drop 0.424V or 3.5%.
Are you really going to need to weld while out on your boat? :lol:
steveh41
Re: 1/0 wire
Post by steveh41 »
Hey chug,
Here's a wire table that might come in handy (I think Carl posted this earlier):
Re: 1/0 wire
Post by chugalug »
I know it's probably overkill. positive busbar will have anchor winch and fuse panels and switches for everything.got alot of smaller wire(mostly duplex)in various sizes for bilge pumps,horn ,lights and other.thanks for the chart.(not sure I understand it tho)
steveh41
Re: 1/0 wire
Post by steveh41 »
Your anchor winch is probably the biggest current draw so you could figure the wire gauge to the positive bus based on that value... negative bus the same. To use the chart, take the "round trip" distance (positive + negative leads) down the left hand side of the chart, then go across to the right to the current column and find the wire gauge (will be different for "non critical" versus "critical" loads). Works pretty well and takes into account both ampacity and voltage drop.
Regards,
Re: 1/0 wire
I think I used 4awg to and from the engine and main switch. I can cross over as a back-up for the starter battery. From the switch to the main dc panel I go to a 50 amp fuse then to the panel with 6. The secondary dc panel and the main panel are linked with 6. I have 3 ground blocks. They are linked with 6. The heaviest dc loads that I have are the VHF radio, water pump, and the head. I doubt I'll be flushing, showering, and using the radio all at the same time. Although, I could :!: :roll:
Re: 1/0 wire
Post by chugalug »
Thanks ,Bill and Steve.My main concern was the length and size of wire to circuit breakers from batteries(about 15 ft).dash switches have fuses on panel.was thinking on running heavy wire from battery switch in rear up to the pos and neg busbars .then smaller wire to each panel then off to loads.Have 150 amp breaker to put on positive wire where accessable.I have the Glen-L electrical plans.
Re: 1/0 wire
I think you should have a main breaker near your power source (battery). Maybe that's your plan already.
Re: 1/0 wire
Post by chugalug »
:D The Starting battery and the house battery go to battery switch first .then common battery + cable goes to 150 amp breaker mounted near batteries,then off to + busbar mounted on back of steering bulkhead. :D
