chine sandwich on Malahini?
Tom J
Postby Tom J » Wed Sep 27, 2017 1:44 pm
I am having a hard time bending the 3/4" mahogany (Meranti) chine log on my frames. I was thinking of ripping them, attaching the first one then glue and attach the second piece on that, somewhat like the sheer. Would this present any problems with fairing and or structural strength?
Re: chine sandwich on Malahini?
Postby Bill Edmundson » Wed Sep 27, 2017 2:01 pm
Many builders do this. It is actually stronger than a single piece. If you use metal fasteners do your fairing with a belt sander.
Postby DrBryanJ » Wed Sep 27, 2017 2:10 pm
I did that on my build. I also concur with Bill on belt sander. My plane blade will attest to that. :oops:
Tom J
Postby Tom J » Wed Sep 27, 2017 4:33 pm
Thank you both... also for the advice on using a belt sander. I would have figured that out after ruining a blade on mine.
Postby PeterG » Wed Sep 27, 2017 9:10 pm
Bill and DrBryan said it best, it's a good idea and makes a stronger chine. You can do it in two or three layers. I would recommend applying them with epoxy first, then install the screws after the laminating is done. Though, if you go with two layers, you may need to use scews at the chine blocking at the stem to hold it better. I made my chines from African mahogany, I think khaya (not really sure) and found at 3/4 inch they were surprisingly flexible. Let's see how they go when I get to installing them..
Postby hoodman » Sat Sep 30, 2017 12:31 pm
When I laminated any of the longitudinals in my boat I only used epoxy, no fasteners. When you screw the planking down the fasteners will likely go into both laminations anyways.
Return to “Wood and Plywood”
