It is currently Sat May 25, 2013 11:13 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: decking
PostPosted: Wed Apr 18, 2012 12:01 pm
hi guys im going to build a flats flyer and i was wanting to do the decks like the classic runabout and was woundering the best way to do it. would i put plywood down and glass it then but the stripping down and and varnish it. i grow up rebuilding and reworking fiberglass boats but this is my first wood boat. i have never use epxoy resin i dont know how clear it cures or anything like that. thanks for all the help
 Post subject: Re: decking
PostPosted: Wed Apr 18, 2012 2:25 pm
In my experience, the easiest epoxy to use is MAS with slow hardener. It dries clear with NO amine blush. I don't know of any other epoxy that is like that. There are lots of other high quality epoxy marine brands around including the Glen-L brands. For safety, my advice is to wear a respirator every time you apply epoxy and especially when sanding it. I have developed a slight epoxy allergy and I get a sore throat and my eyes get itchy. Others get some pretty significant skin rashes.
PostPosted: Wed Apr 18, 2012 5:59 pm
I would say epoxyng the sub deck ply is highly recommended, fiberglassing it a bit over the top and not all that necessary - then apply the fancy deck boards and finish that with epoxy and clear coat.
PostPosted: Wed Apr 18, 2012 7:05 pm
thanks for the input guys it helps alot
PostPosted: Thu Apr 19, 2012 5:19 am
I put the cover boards on with thickened epoxy resin over the plywood substrate. Rather than clamp them in place, I countersunk and bored the screw holes for plugs. Cloth is not needed under the cover boards, but you could put cloth over them. Many builders do not use cloth above the waterline.
PostPosted: Thu Apr 19, 2012 3:42 pm
thank you im glassing everything i want this boat to last
