Scarfing jig
Scarfing jig
I have never done any scarfing. Of the two builds that I have done that required longer than 8' pieces, I used butt blocks. They, of course, leave flat spots. I have seen various techniques and various jigs used to make the scarf joints. Some seemed better than others. I came across one the other day that I believe may be the simplest and most efficient one yet for the amateur builder. The jig is very easy to make and requires a router. The results seem very predictable. Here is the link to a series of photos as part of a lapstrake built Ian Oughtred Guillemot:
http://www.gilesfamily.id.au/Navigator/ScarfingJig.htm
Be sure and take the time to look at all the other photos. Nick built a very nice boat. He has also built a Welsford Navigator. Both were very nice builds.
Re: Scarfing jig
Thanks for the link.
I've thought of that same basic technique, but with the two boards/planks to be scarfed lain side to side and cut simultaneously.
I don't know if that would help or not.
Re: Scarfing jig
Yet another way, one that I used with a similar router jig, is to stack the two pieces to be joined with the scarf. Stagger the upper plank back about (slightly less than) the linear distance of the planned scarf (length b-c in the image) and cut both planks at the same time. Because you can align the length of the planks, it permits perfectly aligned scarf angles.
Paul Miller in Memphis, TN
"Yeah, I had lunch with him last week at the Cracker Barrel out on I-40."
Re: Scarfing jig
I used a router for all my scarfs, both lumber , and, plywood.
There is links to my setup in my Double Eagle build.
If scarfing ply with the router then the Raptor brads would be a big help.
Re: Scarfing jig
14' Mr John-being built
32' Supper Huck-in design
Rod H
Rod H
Re: Scarfing jig
Something like this? Here's what I made.
Re: Scarfing jig
I like it. Now I feel like going out and making some scarfs!lakeracer69 wrote:Something like this? Here's what I made.
Re: Scarfing jig
lakeracer69 looks nice, simple, and straight forward how did it work? Any chance you can post a couple pics of a joint in process and completed? I am looking to do this on my CS build any where butt blocks would show. I am looking for a cleaner look on the finished boat. Thanks Paullakeracer69 wrote:Something like this? Here's what I made.
Re: Scarfing jig
I like the simple design what i have in mind is based on a panel saw but seeing what you built looks good and should worklakeracer69 wrote:Something like this? Here's what I made.
Rod H
Rod H
Re: Scarfing jig
Have one that uses a circular saw too. Have to look for the pics.
The router one will put a 12" scarf on 1/4" plywood. Yes you heard right. I posted this a number of years ago here.
Re: Scarfing jig
12" sounds a little like overkill. I suppose there might be a time when that would be needed. Isn't the standard an 8:1 scarf? That would be 2" with 1/4" plywood.lakeracer69 wrote:The router one will put a 12" scarf on 1/4" plywood. Yes you heard right. I posted this a number of years ago here.
