Question on Zip transom
Bill W
Post by Bill W » Tue Dec 27, 2016 7:07 pm
On the zip plans, I see the sides and bottom members of the transom frame, but not real clear if there is a top frame member. If there is it seems to taper very thin at the center.
Any help will be appreciated.
BarnacleMike
Re: Question on Zip transom
Post by BarnacleMike » Tue Dec 27, 2016 10:05 pm
Bill,
There are top members of the frame, yes. However, they are two separate pieces that butt up against the motor board.
There is not a full-width frame member across the top of the transom on the Zip.
Here is a photo of my transom frame. I hope this helps.
The taper where the top pieces meet the motor board is indeed very thin.
-Michael
Bill W
Post by Bill W » Wed Dec 28, 2016 8:24 am
Okay I see it now. Great help, thanks. Did you glue the frame members together or wait and attach directly to transom ?
BarnacleMike
Post by BarnacleMike » Wed Dec 28, 2016 8:49 am
I did not attach the frame parts together separately from the transom, no.
I glued the frame parts directly to the transom, using thickened epoxy and a lot of clamps. So far, I have not used any screws on the transom.
I attached the pieces all together in multiple stages. First, I attached the motor board:
Then after the epoxy cured, I attached the floor beam and the sides:
Once the epoxy for those parts cured, I attached the top pieces. The key is to cleanly scrape epoxy away from the corners where the miscellaneous frame parts meet the transom. Otherwise, if you let a "bead" of epoxy solidify there, it creates a real headache trying to fit the next piece into place. I use a simple flexible putty knife to scrape away epoxy squeeze-out.
-Michael
Return to “Wood and Plywood”
