Riveria motor stringers
57jimbo
Post by 57jimbo »
Hello, This topic may have already been discussed. If so, sorry for the rerun.
It's been a few years since I joined this forum and after dealing with, "Life", I've finally got around to completing all my frame members for my Riviera build. Time for " Phase 2 ".
I live in the Metro Orlando , Fl. area and I am having difficulty locating lumber long enough for the motor stringers.
The plans indicate the finished stringers to be 16' - 3" in length. All the choices I can find for 8/4 lumber are all 12' ish max.
I can't find vertical grain African Mahogany at all. I can get quarter sawn Sapele, but only 12' ish. Cannot get Doug Fir nor Long Leaf Pine here, only Southern Yellow or White.
Now for my questions.
1) Any suggestions for a good substitute lumber that I could possibly find in 18' lengths ?
OR
2) Would it be acceptable to build-up a beam using 2 layers of 3/4" material, Mahogany or Sapele, Epoxying and screwing together with staggering
joints , similar to a Lam beam used in building construction ?
I welcome your suggestions.
Thank you,
Re: Riveria motor stringers
A laminated beam will be stronger than a single thick piece of timber. Especially using epoxy adhesives. Any weaker spots in one piece get compensated for by the other lamination. If you want ultimate strength, put a layer of plywood between the laminations (probably overkill).
Post by DrBryanJ »
I believe that a built up stringer is preferred to one single piece for strength, but also to prevent warping. My boat doesn't require stringers, but I think that is what has been discussed here before.
Built up is better. I cut my pieces at 60* and stagger the joints. I don't put the joint directly under the engine.
57jimbo
Post by 57jimbo »
Thank you all for the responses. I kind of had an idea that it would be acceptable to do so, and it is good to get the confirmations.
I also like the idea of handling 10 to 14 foot 4/4 stock during the milling process vs. trying to lug around an 18 foot 8/4 slab repeatedly through my planer and joiner.
I am sure i will be turning to the forums as my build progresses and I look forward to the input and advice from others who have traveled this journey.
I have built hundreds of fiberglass boats in the late 70's and early 80's working for Regal Boats. It has been many years and brain cells since those days !
Wood boats are definitely different creatures and I am enjoying every moment building one.
I will post photos as I progress with the build.
Thanks again.
Dave Grason
Post by Dave Grason »
Cruise through the photos on Van Dam Boat's Facebook page. They laminate all their stringers and if it's good enough for them....
Return to “Wood and Plywood”
