Butt joint on side planking
James P
Post by James P » Thu Feb 23, 2017 8:14 pm
I find myself pondering a few things while reading peoples build blogs. One that comes to mind is if you do a butt joint on the side planking and do not plan on painting the hull, won't you always be able to see a seam? I like the natural mahogany sides, not painted.
I am interested in the Zip if that makes an difference.
Thank you for any replies.
James P.
Re: Butt joint on side planking
Post by Roberta » Thu Feb 23, 2017 8:54 pm
There are many ways to creatively cover that seam in a side plank butt joint. Paint trim, stainless steel chevron like emblems are a couple. You don't necessarily need to cut the joint straight up and down, An angle cut can be very attractive. Neatness counts a lot and try to match grain and color and show off that masterful joinery.
Roberta :D :D :D :D
James P
Post by James P » Thu Feb 23, 2017 9:53 pm
Thanks Roberta. I'm not so sure about the masterful part,LOL! Would the factory edges be the best option at the joint do you think?
gdcarpenter
Post by gdcarpenter » Fri Feb 24, 2017 4:40 am
"Form Follows Function"
I kinda like the seam on my ZIP sides, but that's the carpenter in me.
I managed to do a scarf joint, but the difference visually (on the outside) between a scarf and clean butt joint is negligible. I didn't ' want a butt blocker on the inside.
Post by Roberta » Fri Feb 24, 2017 5:47 am
GD's example shows how nice that joint can be made. Looks very planned and natural. I would not use the factory edge as they are usually not very flat and usually rough. Beveling the mating edges can help close the gap, too.
Andy Garrett
Post by Andy Garrett » Fri Feb 24, 2017 12:47 pm
Paint was my only option. :shock:
Bronze screw heads, epoxy, filler, etc. Paint covers a multitude of sins.
Good luck!
Andy Garrett
Return to “Wood and Plywood”
