Questions regarding laminating frames?
DSR
Postby DSR » Sun Oct 15, 2017 11:04 am
Hi everyone,
I'm currently working on the build details for the frames on the TNT and I wanted to see if I could get some info if possible?
Long story short, I'm doing the bottom and side frames in 18mm Mahogany and the double gussets in 6mm Okoume ply. I'm modifying the gussets to span across the bottom frames as single pieces from side frame to side frame and laminated on both fore and aft sides of each frame assembly. I'd like to adjust the molded width of the bottom frame member of frame 2 due to the height of the tunnel roofs and retain the necessary strength of the member.
Does anyone have any calculations or formulas available, as to the difference in "strength" laminating the bottom members would create in regards to the stress loading on the frames?
Thanks!
Codename "Just A Little....."
viewtopic.php?f=23&t=29753
Gayle Brantuk
Re: Questions regarding laminating frames?
Postby Gayle Brantuk » Wed Dec 06, 2017 1:41 pm
Dave,
We don't know of a formula for this. I don't follow your question about changing the width of the bottom frame of #2--we would keep the width as noted.
Return to “Wood and Plywood”
