Frames for Malahini
Oden
Frames for Malahini
Post by Oden » Sun Oct 29, 2017 2:38 pm
Have just received plans, very good.
Frames: is Pine a type of material to be used ?
Regards Oddvar
Re: Frames for Malahini
Post by Bill Edmundson » Sun Oct 29, 2017 3:20 pm
Oddvar
Welcome.
Southern Yellow Pine is often used. But, not White Pine. White Pine is a fast growing tree and is not very strong or rot resistant.
Oden
Post by Oden » Tue Oct 31, 2017 1:35 pm
Thank you for reply.
What are the best material for frames ?
(Norwegian pine is a slow growing pine, so I will check more about its qualities)
Regards Oddvar
Post by PeterG » Wed Nov 01, 2017 8:47 am
Hi Oden! Glen-L has some articles of various woods to use, and they have a great book called Boatbuilding With Plywood that is highly recommended. There is a chapter in the book that addresses various woods. Basically Glen-L recommends Douglas Fir or mahogany for most designs but several here have used white oak (no red oak for boats). But this best point they make is if these are not available where you are, look at the kinds of woods used by local boat builders.
JoeM
Post by JoeM » Wed Nov 01, 2017 9:05 am
It might help if you add your location to your profile or at least let us know where you are from. That way if others are nearby they can direct you to suppliers and common supplies used in that area. I'm pretty new so i'll leave the advice to others, though I second getting the book BoatBuilding With Plywood. Good luck with your build!
Return to “Wood and Plywood”
