Re: Combine board and batten and molded plywood constrution
brigjeff
Combine board and batten and molded plywood construction
Post by brigjeff » Tue Jun 19, 2018 7:54 am
My son and I purchased a 20' runabout that had the bottom, deck and transom planked with board and batten construction. The hull was not planked. The boat is probably a 1930's kit boat from upstate NY, framed with oak. It was powered by a Universal 6 cylinder. The bottom was rough and we replaced it with 5200 (plywood and mahogany planks). We found that planking the hull is beyond our capabilities and contracting the work is +/-$20K, far beyond the value of the boat when completed. Is it possible/wise to complete the boat using molded plywood construction on the hull?
Jeff
Post by Bill Edmundson » Tue Jun 19, 2018 8:07 am
Jeff
The frame looks a lot like the Tahoe frame at the bow. I looks like a cold mold approach would work well. There is a lot of experience with CM here.
Post by PeterG » Tue Jun 19, 2018 8:38 am
Cold molding the planking will work great on your hull, and it'll be structurally strong. You need to determine the thickness of the original planks, then divide that into 3 to get the thickness of the layers you will apply. You can use the methods shown on the boats here with two alternating layers of thin plywood topped with a layer of mahogany for appearance, or even use all mahogany layers. I highly recommend getting the Glen-L book on cold molding.
Post by Jimbob » Tue Jun 19, 2018 9:02 am
Hi Jeff,
As others have suggested, I would go with the cold molded process. It's easy to do, and not expensive.
My hull is 3/8" thick. Two layers of Joubert 3mm (1/8") Okoume plywood. The final planking was done using 1/8" mahogany veneer. A couple of pictures below.
Plenty of help on the forum if you need it.
The plywood layers with the start of the mahogany veneer.
The first plywood layer going on.
brigjeff
Post by brigjeff » Tue Jun 19, 2018 9:04 am
Thank you for the input.
Jeff
GL3z
Post by GL3z » Tue Sep 18, 2018 12:48 am
how's the progress on this?
Return to “Wood and Plywood”
