Joining plywood
upspirate
Joining plywood
Post by upspirate »
Interesting way to join plywood panels:
http://www.duckworksmagazine.com/06/how ... /index.htm
Anyone done this?I don't like the final pattern if you are finishing bright,but for paint it would be ok
tsmitherman
Post by tsmitherman »
I saw a similar method used for plywood canoe construction several years ago. The builder told me that he cut a finger joint pattern from 1/2" MDF, and used a router with a pattern bit to cut the plywood.
If I remember correctly, his fingers were about 3" long and spaced about 1" wide, with rounded tips. After cutting the joints, he epoxied the panels together. The canoe was then finished with FG.
The joints on his canoe really looked pretty good under a clear finish.
I am considering using this method for my Bo-Jest project.
36' 1969 Willard Aft-Pilothouse Trawler
Blog: www.genesisboat.blogspot.com
Knot-So-Fast (BoJest) SOLD
basilkies
Re: Joining plywood
Post by basilkies »
upspirate wrote:Interesting way to join plywood panels:
The question that comes to mind is: What is the shear strength of epoxy as opposed to the pulling away strength? The puzzle joint would break under a shearing type load and the scarf joint has both pulling and shear forces.
It also seems like the puzzle joint would also be spreading the load over a narrower area, so I would guess it would cause a funny flex in that spot. But, hey, who knows, all you can do is test it or find out from someone who has.
ED3
Interesting
Post by ED3 »
But I would not use that type of joint for anything structural. Besides, it is easier to do a regular scarf with epoxy. Just takes a little practice.
BruceDow
Post by BruceDow »
Here is a variation on the "puzzle joint" that is a little more condusive to a bright finish.
(It took me a while to chime in on this, because I needed to get up to the lake to take the picture)
This is the fore-deck of a kayak I built from a kit. The pieces came pre-cut. With some patience, one could create something similar by hand or by using a router template.
The back of the joint is reinfoced with fiberglass cloth and epoxy.
Bruce.
Dow's Monaco Project
Jones
Re: Interesting
Post by Jones »
ED3 wrote:But I would not use that type of joint for anything structural. Besides, it is easier to do a regular scarf with epoxy. Just takes a little practice.
Wise words.
Avoid Haste.
John K
Post by John K »
My first build in the 70's I was able to buy 16 ft marine plywood. No joints on that boat. Cannot find that anymore.
Cec
Post by Cec »
John K wrote:My first build in the 70's I was able to buy 16 ft marine plywood. No joints on that boat. Cannot find that anymore.
I'm not sure I could afford it if I could find it
Some mornings it just doesn't seem worth it to gnaw through the leather straps.
Return to “Wood and Plywood”
