It is currently Sat May 18, 2013 4:38 pm
 Post subject: Clamping Pressure
PostPosted: Tue May 22, 2012 7:04 am
When epoxying gussets and floor timbers to frames is it necessary to use clamps in addition to the screws or do the screws provide enough clamping pressure on their own? Thanks
 Post subject: Re: Clamping Pressure
PostPosted: Tue May 22, 2012 7:07 am
Screws should provide enough pressure...you want some squeeze out of epoxy at the joint but you don't want a starved joint (squeezing all of the glue out). I usually use clamps for insurance in case a screw fails...I also use screws in case a clamp slips off...ironic isn't it?
http://www.unitybuild.net
PostPosted: Tue May 22, 2012 7:39 am
What Bill said.
With epoxy, its not clamp pressure that keeps the bond but rather having enough material inside the joint. Epoxy will soak into the wood and if you are too lean it can actually form voids in the joint, which would make it weaker. Precoating both sides seems to do the trick (instead of just coating 1 side). I would precoat the surfaces with unthickened epoxy then thicken the batch for void filling and mate the surfaces together, screw and/or clamp.
I most cases, I left the screws in.
Ian (aka Iggy)
My Malahini Build
PostPosted: Tue May 22, 2012 1:12 pm
Thanks for the information guys. Iggy - I will take your advice and precoat. Thanks
