Below is some PM correspondence between myself and Bob Perkins regarding vacuum bagging. I expect Bob's info could be of use to others and so am posting our correspondence as a topic. I look forward to hearing any information others can share regarding the vacuum wrapping technique.
Bob, You sure did a beautiful job on your Biscayne.
I've looked at your site quite a bit along with the Joethewoodworker site and I've a couple questions for you regarding the vacuum wrapping. I've already planked my boat with 1/4" sheet plywood (not the 1/8" cold-molding strips) and now I'd like to veneer over the sheet plywood with 1/4" Sapele planks.
1) Are the 1/4" thick Sapele planks okay, or should I plane them down thinner?
2) Does it matter that I used 1/4" sheet plywood instead of cold-molded strips? The hull design is the Clarkcraft Mariner and the plans call for planking the sides with 3/8" sheet plywood, but I used a thinner plywood because I knew I'd be veneering over them.
3) If I remember correctly, you used GelMagic adhesive epoxy. I know you stated that you used less epoxy because with the vacuum wrapping you didn't need the gap filling, but how much less. Did you trowel it with any specific sized trowel or just kind of spread it on with some sort of flat edge?
Thanks for sharing your woodworking knowledge.
Jeff
Hi Jeff,
The Joe Woodworker site was very informative.. That said - I did not use the pump that way.
You need a continuous duty vacuum pump with as much CFM as possible. Mine is 4.5CFM.. I wish I had a 10CFM pump. These are called rotary vane pumps. The higher the CFM - the easier it is to maintain vacuum.
I used System 3 epoxy (mostly because I worked at a store where I could get it at cost)
I slightly thickened with Silica to get it to a point where it would flow, but stay in place. Kind of like mayo...
I used a 1/8" notched spreader - You should be able to get them anywhere.
The 1/4" plank should not be an issue.
If you get the vacuum working right - the clamping pressure is very high.
Think - ~14 pounds per square inch.. = ~2000 lbs per square foot.
HTH
Thanks Bob for your quick response.
I'm glad you brought up the vacuum pump. I was thinking about using the Venturi type system for the cost savings since I have an okay compressor. Of course cost is always an issue, but not the only issue. I'd hate to set up the Venturi system and realize I'd been much better off spending a little more and doing something else. Here's the press kits that VeneerSupplies.com are now offering -
http://www.joewoodworker.com/docs/vacuumpresschart.pdf . My compressor could handle the V2 Plus without a problem, and probably handle the V2 Premium 5 without continuously running, particularly if I got an extra reserve tank. But it sounds like if you were doing this again, you'd just go with the Excel 5 kit (continuous run 5.5 CFM pump). I don't think my wife would be too understanding of spending the $$ for anything much bigger. So, is that your suggestion, go with the 5.5? This pump will be running continuously for many hours whiles the epoxy sets, would that be a problem?
Also, I'd wanted to post my questions to you directly to the Glen-L forum because I think others on the site are extremely interested in your knowledge and experience in this area, but was concerned you might not see the post there, and thus, I might not get your input. With your permission, I'll copy this correspondence on to a Vacuum Bagging topic on the site. I'm sure RobertCugini could add some good additional info to the topic.
Hi Jeff,
Feel free to ask questions any time. I helped Robert with his vacuum too. It took me a while to figure out it is actually pretty simple. But I did not know that at first
Look on eBay or Craigslist for a Rotary Vane Pump. They are designed to run continuously drawing a vacuum.
Mine is a Gast. You only need a hose to connect straight from the pump to the bag.. No Joe Woodworker tanks, etc.
I do not think you could get a very high CFM with a venturi system.. but I'm not sure.
Feel free to repost. I've answered these types of threads in the past - I'm happy to see people giving it a shot.
The quality of the finished product is remarkable.
Ask Robert!
