Can the glassed over wood be left clear?
TUGMYWAY
Post by TUGMYWAY » Tue Aug 07, 2012 12:46 pm
Would like to build with the idea of seeing the wood. How should it be handle , glass over wood areas? Epoxy over glass then what?
Randy
jprice
Re: Can the glassed over wood be left clear?
Post by jprice » Tue Aug 07, 2012 12:48 pm
then some kind of varnish with a UV inhibitor.
Can't leave clear epoxy exposed to the sun. The UV rays break it down over time.
TUGMYWAY
Post by TUGMYWAY » Tue Aug 07, 2012 1:14 pm
Is their much print through of the glass? Maybe I should do some tests?
Yep,know about the UV problem.
Thanks for the input.
Post by Bill Edmundson » Tue Aug 07, 2012 1:21 pm
Once you wet out the glass, you put on 2 or 3 more coats of epoxy to fill the weave. Now you can sand it smooth. It will look gray. just put some water on it and you can see that it will be clear. Coat this with marine varnish or PU clearcoat for UV protection.
Post by kens » Tue Aug 07, 2012 2:49 pm
I sprayed automotive polyurethane paint clear coat over the epoxy.
Works GREAT ! ! !
