Messy
svenole
Messy
Post by svenole » Wed Sep 05, 2012 12:12 am
:?: hi,i was alittle messy when i put my side panels on.can i sand my drips and smudges off :?: i put them on myself it wasnt easy! but it came out nice except for the messy epoxy or messy me :!: im useing Meranti and dont want to get low spots.
svenole
Re: Messy
Post by svenole » Wed Sep 05, 2012 2:16 am
Scraper>then sand? :idea:
jprice
Re: Messy
Post by jprice » Wed Sep 05, 2012 6:24 am
I've found that a surform tool works pretty good for shaving down any epoxy drips/lumps.
svenole
Re: Messy
Post by svenole » Wed Sep 05, 2012 8:38 am
there not that bad >mostly smudges and i wiped the drips flat when they were wet >maybe if i sand them smoother they will just blend in with the first layer of epoxy coating? the smudges were made from epoxy made with wood flour and im useing Meranti ply and it is very dark with epoxy on it. maybe a heat gun uesd very carefully :?: :!: :idea:
svenole
Re: Messy
Post by svenole » Wed Sep 05, 2012 9:26 am
Then theres also high and low grain :!: ,i havent had help so i had to put glue on chine n sheers then the panels and pick it and clamp myself >they went on nice but messy!!!!!!!!!!!
Re: Messy
Post by kens » Wed Sep 05, 2012 5:42 pm
When sanding epoxy lumps on bare wood, the wood is softer than the epoxy. So, you tend to sand low spot around the epoxy hump making it worse,
The thing to do is encapsulate all the wood so that you are sanding all epoxy, and you can sand off the high spots.
I also use a surform scraper, it works well on drips/boogers.
Ches T
Re: Messy
Post by Ches T » Wed Sep 05, 2012 8:41 pm
Where you wiped it smooth it will blend in, however you want to sand it before you recoat it so it will bond.
Ches
khundley
Re: Messy
Post by khundley » Thu Sep 06, 2012 11:21 am
Another great tool is to turn a standard stanley razor blade into a scraper. Ran a fresh new edge along the side of a vice or hardened steel tool to turn a bur, and VOILA! A perfectly good scraper for exactly what you are talking about, took seconds to make, and 100 of em is what, $5? One of the best tools in my shop for guitar building.....helps me avoid a substantial amount of sanding dust.
Ken Hundley
- Stevie Ray Vaughan
Bill CNC
Re: Messy
Post by Bill CNC » Thu Sep 06, 2012 11:57 am
When sanding wood and epoxy drips combo, I mask off the area with 3-4 layers of masking tape, the 3M blue or green works great. As the drip gets knocked down, I remove a layer of tape for the amount of epoxy sanded. The final layer of tape is pulled and just a tiny amount of sanding is needed.
When sanding, ... Tape is your friend. :wink:
svenole
Re: Messy
Post by svenole » Thu Sep 06, 2012 11:57 pm
Thanks,im worried about ruining the Meranti>> pricey :!: ill practice on some scrap > its mostly smudges from my hands>> thanks
