UV protection.
rocker
UV protection.
Post by rocker » Mon Jan 21, 2013 6:08 am
Anybody know if there is an additive for epoxy to protect against UV degradation? :?:
Re: UV protection.
Post by Bill Edmundson » Mon Jan 21, 2013 7:34 am
West has some UV in their hardner for bright work. But, it's not enough. Polyurethane clearcoat is the best. but, many perfer old fashion varnish.
pauloman
Re: UV protection.
Post by pauloman » Thu Mar 28, 2013 11:15 am
you cannot add UV blockers to thermoset resin systems like epoxies. Pigments keep the UV damage to the surface.
99% of clear coat products do not contain UV blockers. Because in the real world few clear coats go over epoxy and the UV blockers are very expensive. Auto clear coat (an acrylic lpu polyurethane is an exception - there are a few others).
And traditional spar varnish has natural UV blockers so good to put over an epoxy basecoat
Z_Wood
Re: UV protection.
Post by Z_Wood » Wed Mar 12, 2014 7:49 am
Hey sorry to bring this post back from the dead…. But wanted to know which brands would be top picks to use over an epoxy base?
Cheers
galamb
Re: UV protection.
Post by galamb » Wed Mar 12, 2014 4:39 pm
If you stick with the prolific marine brands - Epifanes (who also makes the West Marine house brand) or Interlux - it's hard to go wrong. They haven't been in business for many decades because they make a sub-standard product.
If you have deeper pockets there is another product out called "Bristol" (now also available at West Marine). A number of owners have been using it up north here on the Great Lakes and have got really good reports so far - like 5 years without having to recoat - perhaps not as durable under the Florida sun etc, but compared to traditional spar or any of the urethane's, poly-urethane's that is at least double the typical life span.
Graham
Z_Wood
Re: UV protection.
Post by Z_Wood » Thu Mar 13, 2014 2:29 pm
Ah great thanx for the reply. Iv used the bristol finish before on bare wood. But will it stick to epoxy ?
Thanx again
galamb
Re: UV protection.
Post by galamb » Thu Mar 13, 2014 4:27 pm
Yes, Bristol bonds very well over epoxy and from what I have got "first hand" from users, if you want to put on multiple coats of Bristol, you do not need to sand between coats the way you do with many varnishes or other synthetics.
Graham
