Cleaning epoxy pumps
graham mackay
Post by graham mackay » Fri May 31, 2013 5:39 pm
Hi folks,
For those of you using pumps to dipense resin and hardener, what solvents do you use to periodically clean the pumps?
Graham
I am presently constructing a Glen-L HERCULES, hull basically complete.Am going to fiberglass and paint bottom and then turn over. Sides to be planked with10mm yellow cedar edged bead and cove . Engine is Mitsubihi 4-cyl. 39 crankshaft hp.
Re: Cleaning epoxy pumps
Post by Bill Edmundson » Fri May 31, 2013 6:45 pm
Graham
I just buy new ones.
JasonG
Post by JasonG » Sat Jun 01, 2013 2:09 am
I use denatured alcohol.
Bob Perkins
Post by Bob Perkins » Sat Jun 01, 2013 4:26 am
I weigh my epoxy on digital kitchen scale and skip the pumps. They failed me too many times.
scale makes using 2:1 epoxy simple.
I do not use 5:1 - but a simple spreadsheet could generate a list of mix ratios that would work.
Regards,
Bob Perkins
All the Fun Stuff
slug
Post by slug » Sat Jun 01, 2013 8:53 am
Graham; Against what others might suggest, I use lacquer thinner for all clean up. I don't have any luck with vinegar...it takes too long and too much.
jprice
Post by jprice » Sat Jun 01, 2013 11:20 am
I've never needed to clean my hardener pump, and the only time I've needed to clean my resin pump was when it sat for a while and crystallized. For that I just ran it under hot water until it liquified again, and then pumped the goop out.
I'm with Bill. If they ever get to the point where they're really gummed up and not dispensing properly, I'll just buy new ones. They're cheap, and it's a lot less trouble than cleaning.
graham mackay
Post by graham mackay » Sat Jun 01, 2013 4:48 pm
Thanks everybody, Bill you are not taking into account my Scottish thriftiness!
Graham
Post by Bill Edmundson » Sat Jun 01, 2013 5:44 pm
Graham
Ask My Wife if I'm Cheap :!: :lol:
