epoxy types compatibility
Post by Jimbob » Mon Nov 11, 2013 12:35 pm
New to using epoxy. Have been using poxy-grip with great success, but it has a slow cure. Any problems in using 5min epoxy when I need to use a shim on a part that is later glued up with poxy-grip?
jprice
Re: epoxy types compatibility
Post by jprice » Mon Nov 11, 2013 1:09 pm
As long as the epoxy is fully cured, you should be fine. Just scuff up the surface of the cured epoxy (and wipe away amine blush if there is any) and you're good to go.
