Epoxy Clean Up
psaam
Epoxy Clean Up
Post by psaam » Fri Dec 27, 2013 5:33 pm
I've done my first test batch of Poxy Shield epoxy for encapsulation of a stitch and glue kayak. What's the appropriate clean up for mixing containers, rolling trays and rollers? It seems like I'll be doing this many times in small batches but I'm not really clear on the safe and environmentally friendly cleanup. Am I supposed to let any used epoxy set up in the containers and the scape the solid out? What about rollers and brushes?
Paul
Re: Epoxy Clean Up
Post by mrintense » Fri Dec 27, 2013 8:56 pm
Actually, I was not able to keep anything that was used to mix or apply the epoxy. I would let the mixing cups harden before throwing them away. Brushes were a one time use. It might be possible to clean them, but I didn't. I haven't used rollers yet, but I would think those would be impossible to clean. As for rolling trays, you can by thi plastic inserts for these at Home Depot. They are real flexible and it might be possible to remove the epoxy from them once it had set up.
Barra
Re: Epoxy Clean Up
Post by Barra » Fri Dec 27, 2013 10:52 pm
I use small plastic tubs (butter containers etc) and plastic scrapers for mixing. Allow the epoxy to dry and as the tubs are flexible the epoxy will usually come off in 1 piece. Same for the scrapers although may need a bit more work to break off the dry epoxy.
I also use large syringes to measure out the resin and hardener, one for each. These seem to last quite awhile.
Never managed to clean rollers, brushes etc, would go through may too much acetone trying to do this...
psaam
Re: Epoxy Clean Up
Post by psaam » Sat Dec 28, 2013 7:13 am
Thanks guys, this forum is wonderful. Looks like it is back to Depot for me. Syringes and brushes.
cusoak
Re: Epoxy Clean Up
Post by cusoak » Sat Dec 28, 2013 7:24 am
If you go to home depot and buy a sturdy plastic roller tray and use up most of the epoxy then let it dry. Twist the tray and the epoxy will come loose and you can pull it out. You can clean off roller with lacquer thinner, covers throw away. Brushes go to harbor freight and buy natural brisell brushes they are cheep there and then throw them away.
containers use left over butter tubs or any like that.
Jeff
Re: Epoxy Clean Up
Post by Bill Edmundson » Sat Dec 28, 2013 8:03 am
I use cheap chip brushes and just throw them away ( I'd rather drink a beer than waste time cleaning a cheap brush) . You can sometimes get a second use out of a brush by wrapping them in plastic and putting them in the freezer. Always use nitrile gloves not latex. You can turn the glove inside out over the brush to put in the trash or freezer.
Plastic food containers work well and flex enough that you can usually get the cured epoxy out. Same for plastic paint trays. Mini bread pans work well and help keep the mix from heating up. You can also freeze some water in the bottom of one pan then nest the mixing pan in the frozen one. When the pan builds up too much throw it away and get another.
Re: Epoxy Clean Up
Post by kens » Sat Dec 28, 2013 6:11 pm
If the epoxy is still wet, you can clean up with vinegar.
No need for strong chemicals for your hands, drips, spills.
psaam
Re: Epoxy Clean Up
Post by psaam » Sat Dec 28, 2013 7:42 pm
Thanks all for the great tips. Encapsulation started today in earnest and I'm getting a system down.
John56
Re: Epoxy Clean Up
Post by John56 » Mon Dec 30, 2013 3:57 pm
I'm always on the look out for cheap disposable small bowls. I hit the Dollar Stores just after a holiday (Halloween, Thanksgiving, etc) and buy the small paper or plastic bowls. Great for mixing epoxy. Just toss when done.
I can get couple to three uses out of chip brushes using Denatured Alcohol.
But like Bill said so perfectly, I usually just pitch and reach for a cold beer.
raymacke
Re: Epoxy Clean Up
Post by raymacke » Mon Dec 30, 2013 9:42 pm
I second kens suggestion - for me vinegar works as well as any solvent, is more user friendly and MUCH cheaper. The only downside is the shop may smell somewhat like coleslaw. :P
So Many Rivers,
So Little Time....
slug
Re: Epoxy Clean Up
Post by slug » Wed Jan 01, 2014 9:12 am
Sorry guys, but I've tried vinegar and find that lacquer thinner works best for me. After wiping off the excess epoxy I rinse and let the brushes soak in it. After the thinner gets too dirty to use, I use it to clean out the plastic mixing containers after I've wiped out most with a rag. As thinner evaporates rapidly, most gets tossed across the gravel driveway :shock:
I get my mixing tubs from an automotive supply store as they are graduated, and this allows me to easily mix accurate quantities close to what I need. This cuts down on wasted epoxy.
scottinwv
Re: Epoxy Clean Up
Post by scottinwv » Wed Mar 12, 2014 7:34 pm
I use plastic cups, craft sticks and chip brushes. The cups are about $4 for 100 and the large craft sticks (tongue depressor size) are about $5 for 300. Chip brushes bought in quantity are about 40 cents each.
No clean up, just let it harden where it won't build too much heat and toss in the trash the next day.
Scott
BayouBengal
Re: Epoxy Clean Up
Post by BayouBengal » Thu Mar 13, 2014 1:09 pm
Don't use the vinegar on metal tools, it will cause them to rust.
Return to “Epoxy”
