MAS Low-Tox
MAS Low-Tox
Post by Bill Edmundson » Sun Aug 17, 2014 10:08 am
I have just tried this product. First, I've had no reaction to it so far. Second, This stuff is SLOW. At 6 hours it was not tacky but it was still soft. Temperature was low 90's/upper 80's. It also has light green tint. Clear but green.
Gayle Brantuk
Re: MAS Low-Tox
Post by Gayle Brantuk » Mon Aug 18, 2014 11:13 am
Thanks for the feedback, Bill. Keep us updated...
Re: MAS Low-Tox
Post by Bill Edmundson » Tue Aug 19, 2014 12:33 pm
Take Two.
I just tried to do some fabric , dynel. This hardener is fairly thick, viscose. I does not wet out fabric very well. I like it for gluing. But, it doesn't seem to wet out well.
slug
Re: MAS Low-Tox
Post by slug » Fri Sep 12, 2014 9:10 am
I've been using the low viscosity MAS for wetting out 6oz glass on both the Titan (3 years ago) and on the gentry this past spring with no problems.
Re: MAS Low-Tox
Post by Bill Edmundson » Fri Sep 12, 2014 10:39 am
I have the low viscosity resin. But, the Low Tox Hardener is very thick. It is a little difficult to work glass. The good news is that it really fills the weave.
slug
Re: MAS Low-Tox
Post by slug » Sat Sep 13, 2014 2:35 pm
Bill; I just did some encapsulating on the Gentry and added 10 percent methyl hydrate to the mix (permitted according to MAS) and it brushed out really nice.
Re: MAS Low-Tox
Post by Bill Edmundson » Sat Sep 13, 2014 3:34 pm
Thanks. My jug doesn't have a back label with that info. I'll give it a try. It really needs thinning.
slug
Re: MAS Low-Tox
Post by slug » Wed Sep 17, 2014 2:10 pm
bill; I called tech at MAS. Pretty sure 10 per cent is max.
Yakima
Re: MAS Low-Tox
Post by Yakima » Thu Mar 19, 2015 7:59 pm
Like Bill, I have found this stuff to be slooooow. Even after 8 hours at 60-70 degrees, low humidity, it is still tacky. I used West Systems before and done recall this problem....this is slowing down the build. I think low tox or not, its time to make a change.
Greg
Re: MAS Low-Tox
Post by Bill Edmundson » Fri Mar 20, 2015 6:23 am
Greg
I use the MAS Slow hardener. I have very little reaction to it. But. with respirator and ventilation.
