Epoxy and U.V.
svenole
Epoxy and U.V.
Post by svenole » Sat Sep 20, 2014 11:46 am
Hi,im going to try and get things done next week.my problem or concern is I wont have the required coats of varnish over the epoxy on the outside of the hull. ill have 3 coats on it .do you think the sun will damage the epoxy in a couple days ,im sure it wont be out in the all the time and there going to cover it when no work is being done.im taking it to marine mech . to get wireing and motors worked on..thanks
Re: Epoxy and U.V.
Post by gdcarpenter » Sat Sep 20, 2014 2:12 pm
Epoxy UV degradation is a long slow process. if you already have Varnish you will be fine.
svenole
Re: Epoxy and U.V.
Post by svenole » Sun Sep 21, 2014 1:23 am
thanks
