removing bubbles
Re: removing bubbles
Post by chugalug »
:D That stuff is similar to this stuff I experimented with on Chugalug's Bo-Jest.I used some of it with fibreglass cloth in the cabin for'ward mainly for fillers as it was 65 bucks for gallon kit and I already had two kits on hand.read more about it on my thread.when you mix the 2 together,it is reccomended that you whip it up fast(which puts air in it ) and remove bubbles later with torch.I don't think mine was really Epoxy tho it mixes the same way.
Return to “Epoxy”
