Deck Striping
jthurber
Deck Striping
Post by jthurber » Wed Sep 11, 2019 11:57 am
I realize that there has been quite a number of posts concerning tinted epoxy deck striping. It seems that standard epoxy is normally used. Has anyone tried using Poxy-Grip or similar with silica and micro spheres? It appears to take the whitish tint pretty well...
Re: Deck Striping
Post by JimmY » Wed Sep 11, 2019 7:37 pm
I used System 3 silver tip with micro balloons. It is very white.
I have had a small crack develop after 2 years, and I'm not sure why. It may be from stepping on the deck or the mix may have been a bit dry. I would recommend a mayonnaise consistency. The fix should be pretty straight forward, I just need buy more clear.
Brad Tucker
Re: Deck Striping
Post by Brad Tucker » Fri Sep 13, 2019 8:20 am
I used microbaloons because they are white and easy to sand. No issues yet. She does stay in my shop unless on the lake.
Return to “Epoxy”
